Results 1 to 15 of 16
Thread: 84 200X shock replacement/exhaust questions
    Crest California
    3,014
    I have been looking around for a good modern day equivalent to a 200X shock. I know I can just hop onto ebay and buy a nice rebuilt one, or a good condition used one, but I wanted to see if there's anything out there off of a quad or something that will just bolt right in.
    Mine is sluggish on the return, so it's leading me to believe that it needs a rebuild.
    Also, my Cobra exhaust needs to go. It's too loud, and the neighbors are starting to take notice. Anybody know of a good performing silencer system?
    LED obsessed
    2015 Yamaha FJ-09
    goump1995's Avatar
    goump1995 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Louisiana
    167
    Just use the Stock 200x exhaust. My friend uses an old Supertrap exhaust and it's very quiet , if you can find one for a decent price, get it.
    My Trikes:
    1981 Honda ATC250R
    1982 Honda ATC 200
    1984 Honda ATC 200S
    1984 Honda ATC Auto 200X
    1985 Honda ATC 200X (Basket case)
    Southern MN
    1,875
    You say your rebound is too slow on the shock - a couple things to consider. 1.what is you rebound adjuster set at (dial on bottom of shock) you will see it if you look down where it bolts to the swingarm, and there is an arrow on lower shock above the dial to show what setting you have it on. The dial has 4 different settings. 1 would be the fastest rebound, and 4 would be slow. You would want to set it to 4 if you are doing a lot of jumping, and going over whoops, as you wouldnt want a fast rebound. For general trail riding I would recommend a 2 or 3. I dont know what 1 would be used for.. 2. If the seal isnt bad on the shock (oil around chrome shaft) It could probly use a re-charge of nitrogen. I believe the cap on the ressy is removable, but have never had one apart on the 200x. You should be able to bring thr shock to a bike shop, and they can re-charge it for 5-10 dollars if they arent trying to rip you off.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Crest California
    3,014
    The adjustment collar on the shock is just below halfway down, and there's no leaking oil on the shock. It compresses mostly when I sit on it so it tends to bottom out on a somewhat high jump. The forks are good though. I may have to recharge it, the xr shock I just sold had WAY more rebound in it.
    I still don't know what to do about the exhaust. I kinda shoved the inside of the cobra back into the housing, and then used a and wood block to close up the end of the housing a bit. Still really loud. I was looking at some stock exhausts and it looks like they go for about $40 on fleabay in lightly used condition.
    LED obsessed
    2015 Yamaha FJ-09
    Southern MN
    1,875
    I didnt mean adjustment collar for the spring, I meant the rebound adjusting screw. It is located on the lower part of the shock. Here is a pic of what I am talking about - look at the last pic (3rd one) of the 200x showing the swingarm. http://www.3wheelerworld.com/showthr...ades-need-help You see the black dial near where the shock mounts to the lower swingarm- that is the rebound adjuster. Good luck.
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Crest California
    3,014
    OHhh, the little dial inside of the shock mount, right?
    It's right inbetween 2 and 3, so I should twist it to 2 then? I like jumping, trailing, punching it over bumps, and general sideways shenanigans, if that helps.
    Today I played around with compressing it, and if i go all the way down, it will go back up quickly, but the last inch or so it slowly goes back up. It's fine for jumping up to a couple feet up, but otherwise I can feel it begin to bottom out.
    LED obsessed
    2015 Yamaha FJ-09
    6,811
    A heavy duty aftermarket spring is what you need .
    Quote Originally Posted by Xpress View Post
    Jun 2009
    Leander TX
    2,217
    Maybe the problem is it's between 2 & 3 and needs to be either 2 or 3 or right on one of the numbers? I'm not sure how the 200x shocks are set up internally though.
    Crest California
    3,014
    I played with the knob a little bit, and set it between 1 and 2, and that for sure feels a lot better on the rebound, but I still think it needs to be rebuilt, or recharged.
    LED obsessed
    2015 Yamaha FJ-09
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    As Shortline says, if you are bottoming out on jumps you need a stiffer spring. Or maybe just a new spring - they get tired.
    The shock is supposed to damp the action of the spring. You shouldn't try to make the shock stiffer tomake up for a weak spring, it'll muck up the ride.
    Bill
    Custodian of:-
    85 Tri Z - need rear plastics to go with Mosh seat cover
    83 200x - engine being rebuilt but lodging with a friend
    85 250r - also lodging with a friend until I have a new shed
    ....and a different kind of Z
    ATCrider42 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Iowa
    227
    As anyone noticed really nice mono-shocks on ebay selling for $10-$50?? There was an almost brand new OEM mono shock that had incredibly low hours that sold for $55. Another nice monoshock I saw sold for $10. I have a spare mono shock that I'll use for parts when I need to. So my advice, go buy a new one, they're out there. The nice thing is that it'll take you like 30 min to replace it, too.
    But as for the monoshocks selling for so cheap, WTF? These shocks just must rarely need replacing.....I dunno. My 200x feels really good in regards to the rear suspension. This other 200x I looked at recently felt like an old mattress when I sat on it. It was so bad I just laughed and bounced up and down on it like a trampoline. I thought about buying it for parts but the guy was so weird. I asked him if it would start and run and he said "I'm selling it AS IS for $600." Fu*king Dumass
    Crest California
    3,014
    The only times I bottom it out (or rather it feels close to it) is on a high jump, such as higher than 2 ft, but it seems like it should handle that no problem. After adjusting the knob, I went out and. Jumped a few times, and it certainly feels a bit better, but not like i am expecting.
    LED obsessed
    2015 Yamaha FJ-09
    6,811
    Sounds like your spring is sprung/lazy LOL at 2' it shouldnt bottom out that easy unless your nose diving .
    Crest California
    3,014
    No nose diving, I try to land on all 3 or with the rear wheels first.
    Also, does anyone know how the stock exhaust performs comparing to a performance exhaust, like a supertrapp or dg?
    LED obsessed
    2015 Yamaha FJ-09
    Southern MN
    1,875
    The supertrapp or dg pipe will add noticable gains, but at the expense of noise(better exhaust flow). The supertrapp is quieter than the DG, if you leave enough of the changable discs in. I like the supertrapp in the sense that you can fine tune the pipe to make a little more power where you want it - lower end power, mid, or top power by simply adding/removing discs. I think the original supertrapp pipes are becoming harder to come by, where as the DG is new. I personally have a Bassani system on my 200x, and I love it. I re-packed it, but it is still pretty loud, so I wouldnt recommend it if noise is an issue. The bassani is deffinatly a mid/top end gain pipe. Good luck!
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
