Welding on a gas tank isnt hard... As long as you evacuate the fumes.... Glad to see you had it welded, and didnt JB it up!
Looking through the drain for the petcock, it looks incredibly rusting. Better try and get the rust out of the inside of that before you put gas in it. That is asking for a clogged carb down the road....
Ride: 1986 Honda ATC 200x
Following Mods Done:
-Anodized blue block-off plate
-Factory head light and master cylinder guard
-ITP mudlite SP rear tire/Chengshin turf tamer front
-DG reverse megaphone exhaust
-UNI airfilter
-Moose bars/Protaper Grips/MotionPRO twist Throttle
-CEET classic ATC blue seat cover (should of sent it to mosh :-(...)
-Tuned Carb with a 125 main jet
-COMPLETELY restored gas tank
-RED/WHITE PowerMadd Handguards
-1/4" thick aluminum swing arm skid plate!
Its not as bad as it looks but its going to be treated and sealed thanks for the tip
84 200s almost done
84 atc 70 project
welded recoated and some of the stickers are on . !
84 200s almost done
84 atc 70 project
Looks great dude!
-UNI airfilter
