Results 1 to 15 of 16
Thread: trx swingarm on a crf450r
    Dec 2009
    las vegas
    5
    does the trx swingarm bolt up with no mods to the crf frame? is there any grinding involved? can a trx rear shock be used? or do you get something else to go back there, or does the crf rear shock still work?
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    No it does not bolt up. There is no grinding involved, but there is milling involved. The frame is too narrow, the swinger is to wide, and no you cannot take it all off of the swinger, you have to take it off the frame also. The pivot bolt is smaller diameter on a trx than it is on the crf, the pivot bolt is also your rear motor mount and obviously needs to be the correct size to work correctly with no play. The trx shock will work, but only if you custom make and weld a new shock mount on the trx frame like me and jason hall did. The crf shock could work, but you would have no way to know what it would be set up for with the trx linkage. Also it will not mount to the linkage, and the trx linkage will not mount to the crf frame without heavy modification. This is no easy task, me and all the other guys have put countless hours of thought, work and money in our builds. There is more thought and money involved in this conversion than you could ever imagine. Good luck on your build, where here to help.
    86 atc250r stock sand only
    88 NX250 mint rainy day
    Dec 2009
    las vegas
    5
    thank you for the reply. i will think about my next step. another weird idea i was thinking of was cutting the stock crf swinger and cutting the rear off of the trx swinger. then welding the trx back half of the swinger to the crf swingarm.that way the crf frame stays in tact and so does the shock. i know im crazy, but crazy people think of crazy things. haha
    Oct 2008
    Kansas City, KS
    332
    be nearly impossible to weld the two together and have it be strong. The trx swinger is cast which is very very very hard to tig to anything, or even back together. Best be would be to start from scratch. Thats what I'll do on my next go round with this build. Learned alot on my first build and someday will start again from scratch.
    ^ Well said! Cast aluminum is no picnic. It would probably be easier to build a custom swinger.
    Ride height, rake, fitment; It truly is no easy task but were all gonna have to share with these builds while we watch the parts dry up for the OEM trikes...........
    Reservoirs mounted right to the upper mount don't help when you need clearance for other stuff!
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    I'm gonna play devils advocate here and say not only is it possible, but its been done, and thoroughly tested.
Name:	P1010049 (Large).JPG
ID:	109026Click image for larger version.
Name:	P1010047 (Large).JPG
ID:	109027Click image for larger version.
Name:	P1010030 (Large).JPG
ID:	109028Click image for larger version.
Name:	P1010031 (Large).JPG
ID:	109029Click image for larger version.
Name:	P1010034 (Large).JPG
ID:	109030Click image for larger version.
Name:	P1010038 (Large).JPG
ID:	109031Click image for larger version.
Name:	P1010039 (Large).JPG
ID:	109032Click image for larger version.
Name:	P1010045 (Large).JPG
ID:	109033Click image for larger version.
Name:	P1010022 (Large).JPG
ID:	109034Click image for larger version.
Name:	P1010017 (Large).JPG
ID:	109035Click image for larger version.
Name:	P1010001 (Large).JPG
ID:	109036Click image for larger version.
Name:	P1010003 (Large).JPG
ID:	109037Click image for larger version.
Name:	P1010006 (Large).JPG
ID:	109038Click image for larger version.
Name:	P1010013 (Large).JPG
ID:	109039Click image for larger version.
Name:	P1010011 (Large).JPG
ID:	109040Click image for larger version.
Name:	P1010014 (Large).JPG
ID:	109041Click image for larger version.
Name:	P1010154 (Large).JPG
ID:	109042Click image for larger version.
Name:	P1010088 (Large).JPG
ID:	109043Click image for larger version.
Name:	P1010112 (Large).JPG
ID:	109044Click image for larger version.
Name:	P1010135 (Large).JPG
    That was an arm I welded up for Louis Mielke, that was CR500 in the front and 400EX in the rear. It never broke, or cracked with 2(?) seasons racing the OTC MX series before he went to a shorter one.
    Live Oak, FL
    15,069
    And a few more so you can see how it started out.
Name:	P1010113 (Large).JPG
ID:	109046Click image for larger version.
Name:	P1010114 (Large).JPG
ID:	109047Click image for larger version.
Name:	P1010110 (Large).JPG
ID:	109048Click image for larger version.
Name:	P1010109 (Large).JPG
ID:	109049Click image for larger version.
Name:	P1010094 (Large).JPG
ID:	109050Click image for larger version.
Name:	P1010148 (Large).JPG
ID:	109051Click image for larger version.
Name:	P1010082 (Large).JPG
ID:	109052Click image for larger version.
Name:	P1010080 (Large).JPG
ID:	109053Click image for larger version.
Name:	P1010077 (Large).JPG
ID:	109054Click image for larger version.
Name:	P1010069 (Large).JPG
    ^ AND, your also a very good if not excellent TIG welder.
    I'm SURE you've seen some of the aluminum fed mig welders attempting aluminum repairs; Let alone structure........
    Live Oak, FL
    15,069
    No I agree its not something just anyone should attempt, but if you get the thing setup for chain alignment and stuff and make a little fixture (Like Louis did, his was out of a bedframe and then shipped it to me) you can take it a competent welding shop and have them go to town on it. The aluminum actually welded very nicely from what I remember. Infinitely better than any carbon and oil soaked engine cases I've ever had to work on. MIG on aluminum isn't inherently inferior to TIG either, its just a lot harder to be precise with it and you dont have as much on the fly control.
    Dec 2009
    las vegas
    5
    i knew it could be done. on the raptor site, people cut the aluminum stock swinger and extend them. people stretch the suzuki 400 swingers too.
    Oct 2008
    Kansas City, KS
    332
    Yes it can be done...but not by just anyone. And if you were to pay some to do it it would cost more than most bikes are worth to do the welding you just showed pictures of. By the way amazing tig job those welds look amazing on cast.
    Live Oak, FL
    15,069
    Well I tell ya'll what, if anyone wants an arm like that made, jig it up so its in the alignment and placement you want (Use a bed frame, some all thread stock and strap steel, whatever that holds it and makes it fairly rigid) Ship them down here, and as long as I don't have to cut any material to fill in the weld gaps, I'll glue as many of em together as you want for $150 a piece!
    Dec 2010
    florida
    i think No it does not bolt up because it is no grinding involved, but there is milling involved. frame is also too narrow and swinger is to wide.
    It is too good for those users who are not well knowledge. I'll see what I can get out of it or not.ok hope the answer Thank you
    Dec 2010
    South Eastern Va
    123
    Very Nice Work!
    Live Oak, FL
    15,069
    Thanks! Wasn't really that bad to do since Louis had it all in place where it needed to go for me.
