Results 1 to 8 of 8
Thread: Front mastercylinder for a 1984 250R
    Toledo_Tommy's Avatar
    Toledo_Tommy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Toledo
    279
    I can't seem to find a decent front mastercylinder for my 84R (even on ebay) Is there any other makes/models/years front mastercylinder that will work for this. Someone told me a 85 200x will bolt right on but i want to make sure.
    Thanks
    OK
    5,450
    You should be able to use the front master cylinder off of just about anything with a front hydraulic disc brake. Dirt bike, quad, or 3 wheeler.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Nov 2010
    Toledo
    279
    Any examples of models that will for sure work ?
    KX,CR 250,450,125R,250R - They all use the same brake fittings and are cheap and easy to find.
    Go on EBAY and look at some.
    Nov 2010
    rogers nm
    9
    Any honda master cylinder with a banjo bolt will work as long as it is for 7/8" bars try to find early 70's twins on ebay you can use either round or rectangle, only difference is you can see the fluid level on the plastic ones.
    OK
    5,450
    Quote Originally Posted by nickitzi View Post
    Honestly I would look for the newest, cleanest, for the least amount of money. I 2nd Dirtcrasher.. check CR, KX, YZ, and RM dirtbikes for the newest and cheapest you can get. I'm fairly sure that even bikes with 1.250" bars still have a 7/8" mount for the front master.
    http://cgi.ebay.com/ebaymotors/Kawas...Q5fAccessories
    http://cgi.ebay.com/ebaymotors/06-KX...Q5fAccessories
    Rides:
    My feedback thread
    Nov 2010
    Toledo
    279
    Ok, Thanks alot guys !
    I already told you that in your other thread.
