Woohooo!!!!!!!!!!!!![]()
Finally picked me up a couple of new toys!!
And because you guys like big pics...
Dirty toolkit, but there is a completed one with the original sleeve in the parts box.
The parts bike. Doesn't look too bad beneath the plastics, but otherwise, just for parts...
And an owners manual in perfectly legible condition, just a little scratched on the covers. Not sure if these are really worth a whole lot, but if so, I might just sell it (after I make a copy for myself).
I tried firing it up tonight. Mixed up some gas real quickly with what I believe to be an appropriate mixture, poured it into the tank, and the petcock leaks. I think it's coming from the valve itself, but not sure- the 90* bend pops right out, and it doesn't on the other petcock, probably will swap them over tomorrow.
But it was slow enough to where I could attempt to start it, so I poured some gas in (after I cleaned the tank out), turned the choke on, kicked it over about a dozen times, and nothing. Pulled the plug off, and it's soaked, so I'm thinking the engine is flooded? Carb probably needs a clean too.
Anyways, how do you think I did for $500?
Doesn't look bad to me. Little wet sanding on the plastics, some polish, and should look nice. The parts bike is all there, and I think the green one has an aftermarket carb, by mikuni..?The piston shaft is a rectangle, not round...
