while going through my parts,i found a mikuni carb...
it is a little different than other the carbs i have.
one side(presume its the air filter side but you could never put one on it)it is like flat on that side)it measures around 40mm outside to outside.
the other side (looks like you slip the boot over it and clamp it down)
measures around 32mm outside to outside.
the piston opening is about 30mm.
and also the top where the cable go is different it doesn't have the small little tit that the rubber slides on. it is a rectangle that has a slightly offset hole for the cable to go in.
is this even a trike carb?
if so where can i get a boot to attach it to the motor,and what about an air filter?
