Measure the carb O.D. at the intake side flange.
Measure the distance between the frame or nearest obstruction.
Call UNI. Get a Pod filter with a 45 degree boot and tell them waht you carb diamter is..
I think the filter is 3.5 inches long. You have to trim the rubber boot off the filter about 1.5 inches. ( but mock it up first)
Then mount the filter so it kicks up where the coolant bottle goes.
Relocate the coolant bottle, throw on a Outerwear,and call it done.
That is what I did.
The filter sits right up under the front of the rear plastic when done.
Using a bigger carb with the stock restrictive intake system is counter productive.
Proudly NOT a member of
"Team on the Teat"
