Thread: 200x front hub bearings need help
    Aug 2010
    Centerview, MO
    479
    i have looked through my shop manuel and i can not find how to remove the front hub bearings on the 85 200x that i am rebuilding do i need a bearing puller or will something else work also can you push them out one side or do they have to be pulled out there corresponding side
    Angle a long strong punch and tap back and forth/each side of ONE bearing.
    The other you can just smash out..........
    Jun 2009
    Leander TX
    2,217
    Push them out from opposite side with a long drift. I use an old 1/2" extension.
    Bearing removal generally ruins the bearings.
    There is a spacer between the bearings in the hub. You basically push it off to the side to get the drift onto the bearing and whack away with a BFH.
    Aug 2010
    Centerview, MO
    479
    well i got 3/4 of the bearings out the outer peice i belive it is called a race did not come out here is a pic of what im talking about any ideas on how to remove it with out damaging the hub
