Thread: Can Suspension be Added?
    Sep 2003
    18
    Hi, I was wondering if I could some how add suspension to my 200s, if i had the shock, axle and swingarm of a 200x maybe? Its just a thought. Replies would be appreciated, I'm really getting into Trikes!
    -Evan
    Howdy's Avatar
    Celina, Ohio
    10,079
    Re: Can Suspension be Added?
    Quote Originally Posted by New2Trikes
    -Evan
    With some good fabricating skills anything is possible. Now I have seen hack jobs and some really good ones. If you have the parts and the talent give it a try. Frames are easily found if you can't get it done.
    Howdy
    I thought about doing that, there's even a 185 I think on ebay theres a bike that suspention has been added to, I took a 200s motor and dropped it into a 200x frame, it will bolt right in using the 200x mounts and intake. I used the electrics from the s motor, You will have to come up with a way to mount the rear brake pedal onto the 200x frame. I can give you a pic of the solution if you want to attempt it. I figured it was the easiest way to do it right and still have the auto tranny.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    thats an awesome x...s something like that
