As of now, I haven't installed my chain, but I DO know that the countershaft does spin freely. Basically the best way to describe it, is about after 15 seconds of idling it starts to die on it's own. If you hold the throttle open a tad to keep it running, it will still bog and bog as if the engine is "seizing up" because once I let off the throttle, it dies immediatly. The more you hold the throttle open, the louder the knocking noises come from deep inside. By that I mean no more piston movement; dead in the water.
When I try to kick it again, for about the first 5 kicks its really stiff then it starts to loosen up again.
I mean the oil pump was working fine before i took the motor out, and never once did the right side case come off?? The only thing I did was take of the oil lines. But I'm pretty sure there were no blockages when they were reinstalled. If the timing was off, I doubt it would even fire up. If the it was starving oil, I would bet that it would stay locked up after it shut off.
I wonder if maybe there's a vac hose thats not hooked up right or a breather hose? After it runs for so long, it builds up to much pressure in the crankcase?? I'm lost and will probably just take the whole trike back to the engine builder and let him figure it out. I just hope there isn't any damage done.
