High Idling Problem
My 250 sx is idling really high in Neutral (Doesn't do this with any gears engaged)
Ive tried adjusting the pilot screw with no avail
Also took apart the carb and cleaned all the jets
any suggestions?
By pilot screw do you mean the one on the bottom of the carb? Have you tried to manually turn down the idle speed with the screw adjuster on the right side of the carb. Maybe raise the c clip on the main needle.
'85 Honda 200X
'85 Honda Big Red 250es
'85 Honda 250R
'82 Honda ATC 70
'87 LT500R Quadzilla
BRUP!!!!!!!!
What should I raise the clip? One ring? two?....Its on the third ring down right now.....
make sure the needle isnt bent, someone mine got bent on my sx and that thing revved like crazy at times, sometime it even popped out of its slot and stuck wide open, try the middle notch
Got it fixed
Just had to adjust the cable where it goes into the thumb throttle assy
Purrs like a kitten now!!!
//ArrowChat Integreation Code
