Results 1 to 9 of 9
Thread: 1981 250R Rebuild. Advice freely accepted
    Gripit'n'ripit's Avatar
    Gripit'n'ripit is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    Rochester NY
    251
    Melted the piston on my 81 250r air cooled. Looks like the fuel leaned out, but mix was about 30/1. I've been told this can happen when too rich, if there isn't enough fuel to properly mix and dissolve the oil to carry it throughout the engine. There any truth to this?
    Crank seals are good, was not smoking bad when it quit. On the bright side, spanked a 06 raptor 700 off the line. Kid looked like he was about cry. Anyway, the second time is when it broke.
    Any advice for rebuilding or possibly building it up? I'd prefer reliability over performance. At the moment the motors been bored another 1.5 mil over. I'll post pics of the entire project later on. Thanks guys.
    81 250R Custom
    83 250R (in progress)
    98 Scrambler 400
    03 Bombardier Quest 500
    07 Polaris Predator (sold to klondike1020 )
    68 VW Dune Buggy
    Aug 2004
    Ab Canada
    4,368
    Got any more pictures of the piston..The other side's, Crown ect..?
    1985 Tri-Z-
    Southern MN
    1,875
    It dosent matter how much oil you mixed with the gas, you could have mixed it 10:1 and it would have still done the same thing. It looks like it got REALLY HOT, because of an air leak, or incorrect jetting, those will kill a 2 stroke. Make sure if you rebuild it, you replace all the gaskets, and try to determine if it still has an air leak somewhere. Plug chops will also help with the jetting story. If it were a crank seal, it would have been the left one, behind the flywheel, otherwise a bad gasket somewhere in the top end. Sorry for your loss, and hope you get it figured out!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Nov 2007
    Rochester NY
    251
    No apparent air leaks i can find. The chamber with the flywheel is clean. Still got a complete gasket kit and several replacement sets of bearings. Piston damage is mostly on the exhaust side. Damage to the sleeve was minor, but enough to warrant a bore job. As for the intake, i haven't rebuilt the carb yet, but at a glance everything appears fine. Reeds are original, they work, but don't seal down perfect. I'll tell ya more when i get the rebuild kit.
ID:	109568Click image for larger version.
ID:	109569Click image for larger version.
    Off topic, improvements to performance i can make without sacrificing reliability. I'm planning on going from NY to OK to ride at Little Sahara and i do NOT want this to die.
    Thanks for the feed back.
    81 250R Custom
    98 Scrambler 400
    68 VW Dune Buggy
    Oct 2009
    FF, Man.
    774
    Did you run an open air box with out rejetting? Could be a jetting prob related to the cold weather.
    My 3WW Feedback Thread:
    Salut Gilles
    Aug 2004
    Ab Canada
    4,368
    Just My opinion...looks like it Detonated itself to death....and Run hard..with bad fuel....
    1985 Tri-Z-
    Nov 2007
    Rochester NY
    251
    Did not rejet, aftermarket air box on before i bought it. It wasn't running perfect, but okay. I have no idea about the weather, happened 9 months ago (I procrastinate)
    New fuel and oil. Mixed with AMS oil, is this preferred or should i be using something else? Yes, it was run hard. I was just about screaming the engine out when it died. Not the best decision.
    Still going over the bottom for possible air leaks.
    Keep the comments coming.
    81 250R Custom
    98 Scrambler 400
    68 VW Dune Buggy
    Nov 2007
    Rochester NY
    251
    Culprit found. I'm such a jack that i never looked much beyond the engine. 2 cracks/ holes in the carb boot adjoining to the engine. Now all i need to have a ride able machine in a new boot for a 27-28mm carb. Anyone have one for sale?
    81 250R Custom
    98 Scrambler 400
    68 VW Dune Buggy
    Rollingmenace is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2008
    Colorado
    224
    ill have to check if i have a boot i just sold one two weeks ago to another guy on this site.... As far as performance for your 250r theres company flowtek that does porting for the air cooled bikes and from what ive heard is about the best around for getting performance out of these machines... also check out this site alot of good info there http://air foolers.com
    82 ATC 250R (AS $ Crusher.. Project 450 swinger)
    84 ATC 200X (Project Blackout) Hers
    86 ATC 250R
    86 TRX 250R (The Golfcart)
    87 CBR 1000F SSSA STREET FIGHTER
    95 NINJA 250EX
    My Feedback http://www.3wheelerworld.com/showthr...-Rollingmenace
