Results 1 to 3 of 3
Thread: i need help with a klt160 fuel line diagram
    Nov 2010
    oh
    4
    Question i need help with a klt160 fuel line diagram
    so yeah,i have a kawasaki klt160, and im not shure were the lines go(oil and gas) and to which hole on the carbarator and so forth and so on.does anyone know if there is supposed to be a t-piece or something because there seems to be more lines then inputs.
    can somone help with a picture or diagram or something?thanks.
    Nov 2009
    1,147
    If I'm remember right the KLT160 its a simple gravity feed, it should be one fuel line and maybe a vacuum line. There should only be one fitting on the carb the same size as the one on the gas tank and hook those 2 together. But its a 4 stroke so there shouldn't be any sort of an oil line to the carb.
    Nov 2010
    oh
    4
    ok ill take a look at it again
