After 28 years of 3wheeling I'm going to give ice riding a shot, now how the hell do I set up my tires with studs/screws??? Does it ruin the tires?? Can I take the screws out for the summer??? Any help would be appreciated.
What kind of machine, and what tires are you using?
1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
You could probably find some early answers: http://www.3wheelerworld.com/showthr...highlight=srew
Outside of engines with holes that stink, there is no salvation...
My feedback thread: here!
Want to see overseas 3wheelers? http://www.passion-atc.com of course!
YT60 Tri-Zinger, YT70 Tri-Zinger modified, '84 ATC 70, '82 ATC 110, '82 250R, '82 250R modified, '84 250R, '84 480R in build, '85 310R, '86 250R, '87 250ES BigRed, '84 FL250 Odyssey, '85 FL350 Odyssey
20x11-9 Itp pro shots rear.
23x8-11 stock front.
85 250r
Ment ITP hole shots, long day.
ditch the holeshots, there to soft and studs will rip out of the tires
get some 18x9.5? or even 20" chin shing ice tires, get your self a box of 1k kold kutter ice screws and go to town.. i bleave 286? studs per tire on the 18s.... i run 3/4 or 1'' studs in the rear tires, my 300bb 82 250r would rip 3/4s out now and then, so pretty much yes it will ruin the tires
front tire.. run a line down the middle lugs, you can run a line around the next set of lugs from center or every other lug, id start with every other and see how the front bites the ice and add studs if you need to.
wider axle, or wheel spacers on the rear will help you run harder and faster threw the corners, also lowering the tripple trees down 2-4 inches and settin the rear shock soft to alow it to sit lower will help get the center of gravity lower so you can carry even more speed threw the corners, nerf bars are required by some clubs but not all.. iv never ran nerfs on a trike but it seems they would be a good thing so you can get your inside(cornering) foot off the peg so you can get your body weight lower...
And rejet for the cold and tear it up!!!!!... dont use normal screws of sheet metal screws, hex head sheet metal screws work but bite no where near as hard as kold kutters, iv tried kold kutters and pro golds and the kolds are by far a better stud
86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
'let those who slide decide'
Thanks a bunch 4cfed, thats exactly the info I was looking for. Its going to be an interseting transition for me being raised in the AZ desert to riding on a frozen lake, thanks again.
