Anyone here ever done it? I'm replacing the guides in my 200x and I'm trying to decide whether or not its something I want to mess with or just take it to the machine shop.
84' 200x wiseco 12:1, 30mm mikuni, k&n filter, powroll cam, bassani exhaust, 6 speed trans, running on E85
take it to a machine shop. they have to be pressed out and then in. then they have to be reemed to fit the valves.
Valve guide suck to do! In all my years of rebuilding/ building engines. I have rarely ever seen vavle guides worn so bad they needed to be replaced.
Ride: 1986 Honda ATC 200x
Following Mods Done:
-Anodized blue block-off plate
-Factory head light and master cylinder guard
-ITP mudlite SP rear tire/Chengshin turf tamer front
-DG reverse megaphone exhaust
-UNI airfilter
-Moose bars/Protaper Grips/MotionPRO twist Throttle
-CEET classic ATC blue seat cover (should of sent it to mosh :-(...)
-Tuned Carb with a 125 main jet
-COMPLETELY restored gas tank
-RED/WHITE PowerMadd Handguards
-1/4" thick aluminum swing arm skid plate!
do some measuring with a good bore mic and see how far they have worn. if within spec, just change the seals.
Current List of Toys:
1982 Honda ATC185S
1982 Suzuki SP250Z Enduro
1973 Ford F-100 Ranger
2007 Suzuki M109R
^ I've never seen a bore mic that small, more like a test pin, go or no go.............
I had an exhaust guide worn out on my 200x. I checked it by the amount of free play the valve had in the guide. If you don't have an idea of how snug a valve should be it's best to take it to a machinest. I work in a machine shop and we didn't have any split balls that small. If you could find one, that would be thembest way to check.
every 110 or 90 engine that ive broken down all have extremley worn exaust guides... so a solution would be nice.
I don't know about the 110 and the 90 but Honda does still make exhaust and intake guides for the 200x
Iv Done them on small Honda's 110's.. Heat up the head and give them a tap...and the fall out..
1985 Tri-Z-
Originally Posted by mywifeknowseverything
i done a 200S several years ago. i cleaned the head so that there was no oil residue on it and put it in the wife's oven. i can't remember how hot i got it. then with welders gloves took it out and they just tapped out and the new ones pressed in nice.
TPC Trikes Are Awesome
I have done a few, head in the oven, then freeze the guide with spray, taps right out, same going in, head in the oven, guide in the freezer. But after its in, its best to ream the guide for the actual valve stem.
What about leaving the old valve guides and installing new valves? The exhaust valve on my 200x was shot. There was not much play in the guides before I took them out. Would it be ok to just install the new valves, or should I do the guides since I am already there? Sorry, I don't mean to hijack the thread from Mullet_Boy, but the topic is perfect timing. What about seating issues? I guess i will find out when I get the new valves, but should I expect the valves to not seat good? (I can't imagine them being any worse than they were with all the crud on there). : )
85' 350x (newest addition)
85' Tecate (Still dealing with electircal Issues!)
85' Tri-Z (On the back burner)
85' 200x (SOLD)
Leave me Feedback: http://www.3wheelerworld.com/showthr...ack+for+ama009
The head in question has a lot of hours on it. I don't have the tools to measure the id of the guide, but the new valves i bought seem awfully wiggly in the old guides. So i figured I'd replace them while its apart. I'd read a bunch about just doing the oven trick and that sounds easy enough. I guess my new question is with a brand new honda valve and brand new honda guide do i have to ream still? Thanks guys!
I would put the new guide in, and see if the wiggle factor with the new valve gets better, might just be good to go. worst case is you would then just have to bring it in to get it reamed.
Thats kinda what i was thinking. I have to take it in to get a valve job done anyway, just have them check the clearance while its in.
