I didn't see you mention anything about checking wheel bearings, rear brake, chain tension or condition or making sure the clutch was properly adjusted.  If you have done all these things and you are still looking for more power, you have to figure out how much you want to spend.  If you are on a budget, then the first thing I would look into is an atc110 carb and intake and a better breathing filter and a better exhaust.  A new DG exhaust is probably your best bet.  It will be louder than stock, but not real bad.  Stay away from the cobra exhaust.  I'm not sure about the jardine exhausts.  A sl90 or cl90 cam is a good swap as well.  The original performance cams were sl90 and cl90 cams and then companies started making true performance cams.  You can always change rear sprockets for a small increase in power.  These are about the simplest ideas.  After these, you are talking larger bore pistons, stroker cranks, machining the engine cases and all sorts of other things.  Unless you are looking to start doing alot of work and spending alot more money, you would possibly be better off with a larger displacement trike, like an atc185s.  Best of luck with whatever you decide to do and keep us posted.  Don't forget to get a few pictures on here as well.
				Nicholson 500x (Project)
Nicholson 185s
Homebuilt Racer Chromoly Suspension 110  (Ragin Runt)
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
