Thread: Cam Position?
    Nov 2010
    Northern Illinois
    46
    Cam Position?
    82' 185s. The cam itself has a mark on it, a small triangle mark. Which position does this need to be when the engine is tdc? I am not talking about the cam sprocket that has the o mark on top! The cam itself can be turned inside the sprocket 180 degrees then bolted in place. I was told that the lobes need to be facing toward the piston when the engine is tdc. My mark on the cam is on the opposite side of the cam when this is true. I will post a pic if I need to. Thanks everyone.
    Southern MN
    1,875
    Probably one of the most important things to mention first is - what machine is this work being done to? Does the cam sprocket have a mark as well? If so, I would think that the mark on the cam, and the mark on the cam sprocket should line up, if possible. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Nov 2010
    Northern Illinois
    46
    My bad its an 82' 185s. And there is a o mark on the cam sprocket that is to be lined up at the top mark on the cam cover when the engine is tdc.
    Quote Originally Posted by Yamaha_Rules69 View Post
    Jun 2009
    Tunkhannock,Pa
    904
    Cam lobes have to be facing down
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    Remember that the cam turns at half engine speed, so at TDC the cam lobes could face down or up, and the piston will still be at TDC.
    When the lobes face down they face away from the cam followers. The valves are fully closed (there will be a clearance) and the engine should have just fired. When the lobes face up both valves are slightly open together. No way the engine is going to fire then with no compression.
    Custodian of:-
    85 Tri Z - need rear plastics to go with Mosh seat cover
    83 200x - engine being rebuilt but lodging with a friend
    85 250r - also lodging with a friend until I have a new shed
    ....and a different kind of Z
    Nov 2010
    Northern Illinois
    46
    I have seen the error of my ways. The cam was upside down. Runs fine now. Thanks everyone
