Thread: 1985 Atc 110 Master Mechanics, Help Needed!!!
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    ok heres the deal.... picked this 85 110 up for next to nothing, and it has no compression. I started dismantling the engine, took the 4 acorn nuts off of the head, removed the carb/manifold and exhaust, took the 10mm bolt for the cam chain tensioner off, removed the CDI unit as well as the camshaft.... My problem is the head (where the rocker arms/ valves are) moves about 1/2 inch and then STOPS.... i can see clearly between the head and the cylinder, but i cannot for the life of me get the head to go any further.... am i missing something here? Thanks in advance!!!
    Brad
    Currently Trikeless!!!
    swifty's Avatar
    swifty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    sabula iowa
    381
    ive had a lot of them build up white crud inside the head bolt spray some wd 40 down the studs and keep pushing back then pull forward hard by hand it will scrape off and the head will come off
    ACT NOW THINK LATER!
    current trikes owned
    minty 86 250sx my rider
    pauter flat track framed 110-123cc with custom goodies
    pauter mx framed 110-123cc with aftermarket goodies
    joker framed 90-108cc with front suspension
    2007 artic cat DVX 400
    dickson sprint framed 73 green us90 with 110 engine
    Jun 2002
    OH-IO
    816
    I sprayed it with some pb blaster before giving up on it for the night... i will have to go out in the garage later tonight and see if i can get that turd off.... the top of the head (where the motor mounts to frame) doesnt seperate from where the rocker arms are does it?
    6,798
    X2 . Seems the ones left out in the weather have this problem . Lube it up and pull it off LOL .
    Quote Originally Posted by swifty View Post
