Thread: clutch shaft has play need some help
    Canada,barrie,Ontairo
    229
    hey my crank seal went and was taking the clutch off. got to the clutch basket it moved lil from side to side . and also the clutch main bearing that in the right side case it pull in out a little bit and moves side to side .
    i was wondering if this is gunna be a problem cus i have to replace the right hand side crank seal do to loss of bottom end oil . should i just split the case anyway and replace all bearings.
    229
    anybody
    Jan 2008
    Cleveland Texas
    305
    If you got the know how, and the couple extra bucks for gaskets, it wouldn't hurt to split them. Mic everything, see what kind of shape it's in. Replace bearrings and seals, if able.
    -Fathers 1985 200X
    Nov 2002
    Connecticut
    76
    The clutch basket will have some movment as for the bearing I would change it before it gives out.
