Thread: 1984 200es no spark
    dirtdemon's Avatar
    dirtdemon is offline At The Back Of The Pack Arm chair racerFirst time rider
    Eugene, Oregon
    175
    1984 200es no spark
    ok so ive tried 3 wiring harnesses 2 coils but i havent changed out this thing what is it?
    ive replaced everything but this with others and i cant get spark.
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    333
    It is called the CDI. They are not cheap. Try to borrow a known good one, to test, if you can.
    JustEnough's Avatar
    Oct 2009
    Elk Grove, CA
    333
    Wire brush the frame where the coil touches it and that spot on the coil. Sometimes rust or corrosion causes a break in the electrical connection.
    dirtdemon's Avatar
    Eugene, Oregon
    175
    Quote Originally Posted by JustEnough View Post
    im a step ahead of u but i tried a good one and still have no spark theres a little gold thing that sits at the back of the frame that is connected to the wiring harness
