Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 115
Thread: Flat track pauterbuilt pj1 build
    MN
    632
    A little progress
    So I got a few things powdercoated black. New tapered steering stem bearings and new axel bearings and seals. Trying to use all new zinc plated metric fasteners to match the zinc frame.
    Also picked up this Pauter cylinder. It has the 6mm spacer plate already casted into the cylinder. I was told these were made by Pauter specifically for the 180cc motors. This one has a thicker sleeve and a oil passage and tapped hole for an oil cooler setup which I will be running.
    Attached Thumbnails Attached Thumbnails DSC02991.JPG   DSC02992.JPG   DSC02994.JPG   DSC02993.JPG   pauter4.jpg   pauter1.jpg
    Baltimore, MD
    6,088
    I have one of those cylinders, it doesn't have a predrilled hole in it though. Not sure if that hole is original to the cylinder or not, but I don't think it is. I could be wrong. Thanks for posting, I'd been looking forward to the next installment of this build.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    MN
    632
    Motors
    Gonna use a little of both of these for this project. One with the hi/lo conversion and manual tranny has the cases bored out to fit a 61mm cylinder but has a smaller cylinder and a 58mm stroker. The other one's cases are not bored but has a larger stroker. Not sure what cams these are but they look similar to each other.
    Also a pic of the head side cover oil outlet. I plugged the spot where a brass 90 was threaded in. My second line for the oil cooler will come directly from the pauter cylinder.
    Attached Thumbnails Attached Thumbnails c2.jpg   c1.jpg   PICT0091.jpg   PICT0093.jpg   PICT0088.jpg   PICT0090.jpg
    MN
    632
    Polished aluminum
    Well, I finally got the stuff back from getting polished and it is sweet! The old skool offset 2 piece rims look great on the new replica old skool flat tracker tires. Thanks Mike, for the idea They are wide and hold the rubber out nice and flat.
    The fork tubes are now in the process of getting put back together with new seals and oil.
    Attached Thumbnails Attached Thumbnails PICT0088.jpg   PICT0087.jpg   PICT0086.jpg
    H95Shooter's Avatar
    H95Shooter is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2010
    north dakota
    174
    is that farm homeade i know dumb question
    swifty's Avatar
    swifty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    sabula iowa
    381
    no its a aftermarket frame same as the one in my display pic... sorry to jack the thread lookin good
    ACT NOW THINK LATER!
    current trikes owned
    minty 86 250sx my rider
    pauter flat track framed 110-123cc with custom goodies
    pauter mx framed 110-123cc with aftermarket goodies
    joker framed 90-108cc with front suspension
    2007 artic cat DVX 400
    dickson sprint framed 73 green us90 with 110 engine
    6,811
    Very nice !!!!!!!!! Them wheels look like they cleaned up like new .
    H95Shooter's Avatar
    Dec 2010
    north dakota
    174
    sigh i was hoping i could buy one any body making them or would i need to make one the hard part for me would be making the real axle part
    H95Shooter's Avatar
    Dec 2010
    north dakota
    174
    needed a free bumb
    MN
    632
    forks done
    Got my forks rebuilt and installed. Just got the front tire on the new front rim. Now I need to cut the front axel spacers and install the front tire. Got the aftermarket footpegs installed on the freshly powdercoated bracket.
    Attached Thumbnails Attached Thumbnails PICT0089.jpg   PICT0091.jpg   PICT0090.jpg   PICT0093.jpg   PICT0094.jpg   PICT0095.jpg
    6,811
    Looking good !!!!!!!!!!!!!!!
    swifty's Avatar
    sabula iowa
    381
    cant wait to yours done with fenders, is this frame actually called a pj1 model or just going to be pj1 themed?
    swifty's Avatar
    sabula iowa
    381
    heres a diffrent pic of mine with that frame for some inspiration, i need to do some cleaning on mine but its done and runs, and i need to add the aluminum front wheel also
    plymouth,il
    1,231
    That is one sweet ride swifty it's like a rat rod trike I love the shifter is that a hurst. I think the tank would look better in a nice cherry red though. The upside down bars are sweet to does it bust your knuckles in sharp turns or doughnuts.
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
  15. #30
    swifty's Avatar
    sabula iowa
    381
    Thanks, yeah i got a flat black tank also for when i take it to vintage torque fest, its a big rat rod show in april, im also getting the tank on it repainted, the shifter is a car 4 speed hurst with a b&m handle, the bars are actually on correct they are motorcycle cafe racer bars, just wanted a diffrent look and this style frame made it work, i can wait to see 90crazy's when its finished to see a diffrent style of this frame build. keep up the progress 90crazy a lot of us are excited to see yours done!
