Results 1 to 7 of 7
Thread: big red sputtering at low RPM
    pudge is offline At The Back Of The Pack Arm chair racerFirst time rider
    CT
    159
    my buddy has an 86 big red 250es. he got it a few weeks ago. it sputters and hesitates when you just start to give it gas, like at start up of after making a turn in the woods. then it suddenly runs perfects and jerks up to speed running smooth. it seems to happen mostly in 1st and 2nd gear because on the others the rpm can be kept higher. it idles fine. he says the gas is new, but im not sure about that
    i figured maybe the air filter was clogged because he bought a uni and over oiled it. i removed that and it still happened
    then i figured there was some rust in the petcock or at that screen, it was kinda gunky so i cleaned it, didnt fix it.
    so the next option was to clean out the carb, which i did with cleaner and my air compressor, it didnt help. i never rebuilt an 86 carb before, one hole where a jet would go on the 85 was plugged with a rubber thing, i dont know
    any ideas?
    new carb kit? new gas? air-fuel problems? i wanna get this thing out of my garage so i can tune up my 86 sx and do the rear swingarm bearings on my 85 sx
    Oct 2007
    Minneapolis mn
    4,067
    Carb kit...
    CT
    159
    thanks , thats what i figured. i have had good luck with a good cleaning but a kit is only $20, it needs new gaskets anyhow
    Nov 2009
    australia
    9
    Gaskets not the problem,I think you need to look at your jets .
    CT
    159
    Quote Originally Posted by kos kruiser View Post
    i know the gaskets arent causing the issue, i was saying that they need replacing, they are dried out. the carb kit is only a few bucks more that the gasket set
    Oct 2007
    Minneapolis mn
    4,067
    Be sure to check the new jets out carefully... I had a new kit for my BR from Dennis Kirk, new jet was labeled correct #, but the hole was monsterous! Had to have been 30-40+... Never ran right till I ordered a new kit, again...
    CT
    159
    turns out it was the ignition coil had it tested and it wasnt up to snuf. ordering a new one, we'll see how it goes
