Thread: 250r rear rims and tires ? ?
    Toledo_Tommy's Avatar
    Toledo_Tommy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Toledo
    279
    Will the rear rims off a 86 honda 250r fit on my 1984 honda 250r ?
    Thanks
    Nov 2010
    Toledo
    279
    I'm really trying to find wheel spacers for my 84 250r and most of the wheel spacers i have found are for 85 - 86 250r . Is it the same bold pattern ? If anyone knows that would be great.
    Thanks
    myles's Avatar
    myles is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    ontario
    162
    1983/1984-- 8x8 4/110 1985/1986--9x9 4/110
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    the problem you will run into is the studs on the 84 hubs are alot shorter than the 85 -86 . the wheel pattern is the same . wheel spacers (the block type) should work just fine since you have to punch out the studs anyway.
