Do i need the Honda puller to get the rotor of the crankshaft or will a similar puller work fine
Its better to use the honda flywheel puller if you can get one. It threads into the flywheel hub and pushes safely against the crankshaft to pop the flywheel. I used a small 3-jawed puller on an ATC110 once in a pinch, but i had to grind the jaws down to get it to work. There is a risk of damaging the flywheel and more so the end of the crank, so i wouldnt recommend doing that way unless you have no alternative.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
The aftermarket ones on eBay work ok also, and sometimes you can just find the right size/thread pitch metric bolt at the hardware store
Rob
