Thread: 200X Idle
    Feb 2009
    Liberty NY
    49
    200X Idle
    I have a 1985 200X that I rebuilt over the summer and it has been a great machine the only problem I am having is that with the cold weather the machine does not want to idle it stalls. I have rebuilt the carburator with a new kit but it seems that it hangs up on the high idle for a while but then when it kicks down it stalls. Any suggestions appreciated.
    Sep 2007
    100mi west of Chicago
    3,582
    I had the same issue. Only a new eBay carb fixed it. I rebuilt, cleaned, fiddled with the stock carb and could never get it right
    Rob
    6,819
    When the throttle valve/slide get worn its hard to get them to idle correct .
    CanadianThomas's Avatar
    CanadianThomas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Okanagan BC Canada
    270
    Might want to try spraying starter fluid at intake connections, might be an air leak. Thats what stung my 200x, had a bad O ring but it didn't leak until it was cold out and the Trike had warmed up.
    85 Honda 200x, rider build almost complete, need aftermarket rear shock.
    85 Honda 250es, with some work to do.
