I have a 125m honda 3 wheeler and works great until you give it half throttle then it will bog out. Need help.
Sounds like carb problem,
I have cleaned the carb like 6 times and even tried a different carb that work on a different 125m trike, still same problem. I have also put fresh gas in it and changed the oil.
It works fine on anything less then half throttle still????
Have you cleaned or replaced your air filter?
Rides:
1982 ATC70 (Lifan manual 125)
1987 LT80 (piped, widened)
My feedback thread
RIP Trace.. Godspeed.
Air filter looks almost new. It has no decay and no holes in it or anything.
