mixed up fuel and air lines
I recived a 1979 honda atc 110 from a friend, whose son tried to replace old air and fuel lines. during this process he forgot which lines go where. and now there is gas coming through the air filter. the bike was serviced right before the hoses were changed.
is there anyone that can help me with this conundrum? schematics a well written description...anything that would help will be greatly appreciated
Gas in your air box could mean your float is not shutting off the flow of gas into the bowl. It's hard to mess up what goes where on these carbs. There are 2 fuel inlets on the petcock, one for normal and one for reserve. They are marked O and R I believe. Then there is the air vent on the side of the carb, and a drain on the bottom of the bowl.
http://www.bikebandit.com/houseofmot...m1867#sch22717
Rob
thanks, I will start with the float...
//ArrowChat Integreation Code
