Thread: flywheel puller
    Nov 2010
    Louisiana
    109
    flywheel puller
    What is a good flywheel pulling tool or technique?
    blkstangman88's Avatar
    blkstangman88 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    marysville
    282
    $11 for the bolt or puller and screw it in lightly. the fly wheel will pop rite off
    Sep 2007
    100mi west of Chicago
    3,582
    What trike are you pulling the flywheel on? Some use a harmonic balancer style puller to pull the flywheel while others use a bolt that threads into the flywheel to push it off the end of the crank
    Rob
    Jan 2008
    Cleveland Texas
    305
    Alot of the bikes can use the swing arm pivot bolt to remove it.
    -Fathers 1985 200X
