Check the oil in the differential, the thing on the rear axle, check the main oil, take a flashlight and check the inside of the tank, check that the shocks dont give too much, or are froze up, if it starts and runs good then the carb may not need to be taken off and checked, air up tires. After sitting I will crank something and let it sit and idle for a while.
Sounds like you made a score bud!
