Results 1 to 7 of 7
Thread: fuel running out of carb bowl?
    Nov 2010
    Middle TN
    3
    Hey everyone, I just picked up an 85 atc250sx, runs good but unless I shut off the fuel, when I stop it all the gas in the tank will run out the bowl overflow tube. Obviously somethings sticking, but what might that be?
    Dec 2010
    S.E. Illinois
    1,178
    sounds like the float is sticking to me.
    Springfield Mo
    3,309
    Like Jon Boy said. Float is sticking or it is not closing all the way and needs to be adjusted.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Oregon
    2,471
    clean your carb.
    Leonardtown, MD
    594
    make sure your carb is fitted into the boot correctly. i have found out that if i do not have my carb situated right then it will leak out of the overflow tube
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Lauderdale County, Alabama
    2,029
    If cleaning and setting the float doesnt help, you may end up getting a rebuild kit, but setting the float should stop it.
    Nov 2010
    Middle TN
    3
    Thanks guys, I'll give it a good cleaning! I went ahead and ordered a carb kit, figured I might as well do that while I have it out
