Results 1 to 15 of 17
Thread: Which Sealant to use - for HEAD Gasket ? Pic's inside
    Oregon
    2,471
    Question Which Sealant to use - for HEAD Gasket ? Pic's inside
    Well i have these to Sealant's, Not sure what i should use.
    This is for the Head Gasket.
    Oct 2009
    brazil indiana
    839
    i have never used anything. just clean both surfaces real good and dry. then put the gasket on.
    TPC Trikes Are Awesome
    Aug 2009
    Chesterfield, Virginia
    845
    Don't use anything on a head gasket
    TRIKE INTERESTS
    A1/A2 TECATE's
    BIKE INTERESTS
    ATK, Husqvarna, Maico, Harley Davidson & Yamaha Twins
    PLEASE KEEP AN EYE OUT FOR THE FOLLOWING STOLEN 3/30/2012
    1999 ATK 260LQ ENG# 425681 Red/White/Blue VIN# 4MAV1CC43XA009376 (Its the last one missing out of four the first three were destroyed)
    My Feedback
    Nov 2009
    1,147
    If you want to use anything Permatex makes CopperCoat in an aerosol, specifically designed for head gaskets. It was recommended to me buy a guy who build race engines. Also it never goops up like the stuff in tubes. I like it but its not necessary. But I wouldn't put either of the things you have on the head gasket.
    I don't use anything.
    Threbond is for places where there is no gasket - Rocker arm covers, some center cases etc.
    Head gaskets, I stone the 2 surfaces flat, removing all high spots, and use the OEM gasket whenever I can......
    Oregon
    2,471
    This gasket going on a big bore / resleeved stock cylinder, biggest problem with these cylinders
    Are leaks.
    So they recommend a good sealant to eleminate any leaks.
    The last gasket was coat with copper sealant, on this cylinder.
    Oregon
    2,471
    I covered it with - ThreeBond 1104
    I hope it works !
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by ceaserthethird View Post
    I hope it works !
    spray copper would've been better, but 1104 was the better of the two choices
    2-stroke lover
    Dec 2010
    Pennsylvannia
    42
    i didnt know you could not use a gasket i always thought you had to use a oem gasket for the head and that werent supposed to re-use them but i guess theres more than one way to skin a cat as they say
    Dec 2010
    so. ill.
    41
    Quote Originally Posted by 98rangerll View Post
    always use a gasket!
    theyre saying they use the gasket and nothing else
    is it a custom BBK with a piston from a different bike? i would at least get an oem gastet and trim it down.....
    -94' trx300FW:blue, warrior front shocks, 300ex rear shock, 300ex rear hubs, rincon rims, 25" executioners, cycle country boot guards, quad mag shock covers, warn 4-2-4, 3000lbs winch, k&n, cobra full system, blue T.H.E. lock on grips, 250BR cam chain, EBC clutch with spacers on springs, custom reverse lever, snork'd, 250sx cam
    -85 200x: 200S motor, 1 tooth up front sprocket
    -85 200x: megacycles cam, wiseco top end, custom heel guards, full cobra, k&n, irazr radial rears, trail wolf front.
    Dec 2010
    Pennsylvannia
    42
    ok i misunderstood lol im rebuilding 2 85 250sx and i got complete gaskets sets and oils seals and im planning in ussing a light coat of high temp permatex rtv on each side of all the gaskets except the head i always thought ussing rtv on the head even being high temp could over heat ond or goop up and mess up the head am i wrong on that
    ctbale is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    anchorage alaska
    289
    you can re use a copper gasket many times, but ya have to anneal it. (make it soft again) Get it red hot with a propane torch (800f) then quickly dunk it in water, that will get the copper "dead soft" then clean it with scotch brite. (Or just buy a new gasket) installed dry is better.
    Nov 2002
    Connecticut
    76
    You did right buy the threebond we use it on our LTR head gaskets.Curtis sparks also made sure we did this back in the R days.You only want a thin film on it I put some on my fingertip and rub my two fingers together then put the gasket between and go around the gasket.You should hardly be able to see it. Also make sure both surfaces are clean i use lacquer thinner to make sure its oil free.If you put to much on you have a chance of clogging you water ports.
    YOU WANT TO USE 1211 THREEBOND!
    Oregon
    2,471
    Dam I used ~ ThreeBond 1104
