Results 1 to 8 of 8
Thread: HID tecate lights
    blackstone/ma
    1,491
    HID tecate lights
    Okay, I'm getting a little ahead of my self now but was wondering if anyone has had any luck or experiance with setting up an hid Light for there tecate or trike in general??? down the road but can't help but wonder???
    blackstone/ma
    1,491
    Has no one even attempted this???
    Spring, Texas
    450
    I am going to do this to my 200x. I havent' tried it yet though. It should not be too hard. just tie in your ballast to the original light wires? Are you going to keep your stock light and just modify it for your bulb to fit inside of it, or are you planning on replacing the stock light fixture?
    85' 350x (newest addition)
    85' Tecate (Still dealing with electircal Issues!)
    85' Tri-Z (On the back burner)
    85' 200x (SOLD)
    Leave me Feedback: http://www.3wheelerworld.com/showthr...ack+for+ama009
    Spring, Texas
    450
    85' 200x (SOLD)
    Sep 2005
    MICHIGAN
    2,027
    http://www.kxriders.com/forums/index.php?topic=8353.0
    For the KX500 but if you have a timing wheel it should work, dont know about the power curve though
    86 T3
    84 T3
    86 KX250
    I have to question whether or not this will work. The Tecate has a huge jump in voltage from idle to full throttle. I have never tried it, but I must say I am slightly doubtful that it will work.
    Jul 2003
    Las Vegas, NV
    124
    if the trike does not have a regulator you will need one. moose makes one that is available from parts unlimited. the other thing to consider is the HID ballast does not like voltage spikes and fluctuation like a halogen or incandescent light. Therefore you might want to consider installing a battery eliminator..yes I know your trike prolly does not have a battery, but what the eliminator does is smooths the voltage coming from the stator, the eliminator is pretty much a capacitor than can handle voltage spikes and drops. You also need to make sure you have DC going to your headlight, many of the older trikes use AC voltage, and that will kill your ballast.
    edit...ok, the link to the 3wheeler HIS thread is pretty much exactly what Im saying...guess I should of read it before I typed all this crap out!
    F.U.2 RACING
    Atc90, bandito frame
    Atc185 x2
    82 250 (300 kit)
    83 250R
    200ES Big red
    Atc200X (with lifan motor)
    blackstone/ma
    1,491
    Does anyone know the easiest wat to measure the watt output of their stator. I know you can mesause volts and that awatts over volts is amps but how do you measue the potential amp output.... I am assuming load tester???
