Results 1 to 3 of 3
Thread: Oil seal replacement
    Jan 2008
    Cleveland Texas
    305
    Quick question.. Doin a rebuild and i can see the little spring on the seal for the output shaft has came out. Since the bearing is in the case, i cant put it back in. I want to make sure it is not to hard to pull the seal out and put another in. If not, i'm going to go ahead and replace them all.
    Quick procedure of replacing a seal?
    thanks guys.
    -Fathers 1985 200X
    Spring, Texas
    450
    Hey Kasey, I just saw your thread after I responded on mine. I don't know about changing the seal with the shaft still in there. Is it leaking any oil? The seal is supposed to put just enough pressure on the shaft as to not lose oil, but it is not so much that you couldn't slide it in or out. I think you will have a harder time removing the seal from the case. I don't know if you can get enough bite on it with some needle nose to pull it out. I am not sure, but I think that once you have the old one out, putting in the new one may be a lot easier. I used a socket(i don't remember which size) to tap the new one in. You may be able to do the same thing. IDK, just trying to give you some ideas. Of course, if you are not leaking any oil, you may be ok.
    85' 350x (newest addition)
    85' Tecate (Still dealing with electircal Issues!)
    85' Tri-Z (On the back burner)
    85' 200x (SOLD)
    Leave me Feedback: http://www.3wheelerworld.com/showthr...ack+for+ama009
    Dec 2005
    Wisconsin
    1,141
    If it isn't leaking don't worry about it. To change a seal with the shaft in drill a small hole in the seal, thread a small sheet metal screw into the metal part of the seal and pull it out with a pliers. Take a socket that fits the seal and pound in the new one. Before you put a seal pack the back of it with axle grease, this will keep the spring in place.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
