Results 1 to 3 of 3
Thread: Tire Width compared to Rim Width???
    Plattsburgh, NY
    2,311
    How crucial is the tire width to the rim width??
    Seems like the most common is 2 inch wider tires then the rim it's mounted on. But is it still ok to be only 1 inch wider tires then the rim??
    I have a set of 20x11x10 tires that I want to mount on a set of 10x10 inch rims. This should be fine right?? And on the other end of that would it be ok or better to run the 20x11x10's on 10x8 rims?? I just thought that a 3 inch wider tire then the rim was too much. But a lot of tires that r for 10 inch rims are 11 inches wide and then most of the 10 inch diameter rims r 8 inches wide.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    IMO you can play with these things. I doesnt matter much, all it would do is change the overall shape of the tire.
    For your question if 1 inch wider tire is ok, it would be just fine, only thing is getting it on the rim but it should be easy. Keep in mind: thats just 1/2 inch on each side.
    I got 10'' wide 4snows on 10'' wide rims, and it fit just fine. Just need to watch for rocks when going sideways because the edge of the rim sticks out.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Dec 2010
    so. ill.
    41
    as long as the tire width is the same or wider thn the rim width youre good to go. i have 12" wide tires on 7" wide rims, 8" wide tires on 6" wide, and 10" wide tires on 7" wide rims. 0 problems. but the only thing you have to remember is that the wider tire on a narrower rim will be taller.
    ex. 25x10x12" tire on 12x6" wide rim will be taller than a 25x10x12" tire on a 12x8" wide rim.
    -94' trx300FW:blue, warrior front shocks, 300ex rear shock, 300ex rear hubs, rincon rims, 25" executioners, cycle country boot guards, quad mag shock covers, warn 4-2-4, 3000lbs winch, k&n, cobra full system, blue T.H.E. lock on grips, 250BR cam chain, EBC clutch with spacers on springs, custom reverse lever, snork'd, 250sx cam
    -85 200x: 200S motor, 1 tooth up front sprocket
    -85 200x: megacycles cam, wiseco top end, custom heel guards, full cobra, k&n, irazr radial rears, trail wolf front.
