Not to sound like a jerk, but if you work on your grammar you will get more responses.
It sounds somewhat obvious that you are having a fuel problem. Does gas come out of the gas line if you remove it from the carb? It could be blocked in the tank. If it does come out, then you might be having a problem with the needle and seat in the carb, or the passage going to the needle and seat could be blocked. The main jet could be blocked as well.
