Results 1 to 3 of 3
Thread: 86 200x jets
    4cfed's Avatar
    4cfed is offline Just Too Addicted Arm chair racerJust too addicted
    Oct 2009
    wisconsin
    619
    86 200x jets
    so its my understanding that the 86 200x uses a 112 main stock, which my bike has, only mod is a fmf muffler, but its also cold out 35 degrees or colder ( ice riding)..
    i took it out last fridaynight and it was around 28 degrees out and i noticed my header glowing slightly.. onyl about a inch or 2 worth were glowing and i couldnt notice it unless the light was off, only does it when running wide open throttle, idle, and mid range it done glow so i know i need a bigger main.
    i know you cant jet over the internet but im lookin for input on what other guys are running for jetting on the main to get a idea of what to run. i dont know if 120 is gonna be enough or should i go to a 125,
    i still have the lid on, and a stock style foam filter, just the fmf megamax2 muffler welded on it, winter riding ill be riding anywhere from 35 degrees down to 0 degrees
    86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
    Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
    'let those who slide decide'
    Nightmare's Avatar
    Nightmare is offline At The Back Of The Pack Arm chair racerFirst time rider
    lehigh valley, PA
    196
    I have stock bore but completely refreshened.
    -Full DG exhaust
    -UNI airfilter (no inner spark arrestor)
    Cleaned the carb perfectly.
    Installed a moose carb rebuild kit to start.
    -Tested numerous configuration and stuck with this. ---- Stock pilot is #35 main is #112----
    --#38 pilot jot with #130 main jet. I have the needle in the middle, and air screw out about 3-1/8th turns out. Air box lid on. My spark plug has a nice tan color.
    If you have a white tip, your lean. If you have a black tip your rich. Try adjusting you needle up or down to. To richen your mixture with the needle, move the circlip down, to lean out move it up.
    I would say a 120 is probably enough if you only have a slip-on and stock airfilter with internal spark arrestor. If you have a UNI, TWIN AIR, MOOSE, etc airfilter. Maybe a 125 might be ok.
    Ride: 1986 Honda ATC 200x
    Following Mods Done:
    -Anodized blue block-off plate
    -Factory head light and master cylinder guard
    -ITP mudlite SP rear tire/Chengshin turf tamer front
    -DG reverse megaphone exhaust
    -UNI airfilter
    -Moose bars/Protaper Grips/MotionPRO twist Throttle
    -CEET classic ATC blue seat cover (should of sent it to mosh :-(...)
    -Tuned Carb with a 125 main jet
    -COMPLETELY restored gas tank
    -RED/WHITE PowerMadd Handguards
    -1/4" thick aluminum swing arm skid plate!
    4cfed's Avatar
    Oct 2009
    wisconsin
    619
    thanks for the reply. i got a 125 main, i figure if its to rich i can take the lid off, ( easyest way to adjust for temp changes) like i said its cold out and when ONLY on the main the header would glow, could leave it idle for 10 min and it wouldnt, ride it 1/4- 3/4 throttle and it wouldnt glow, but once i made awide open throttle pass it would glow, id rather be a little rich for cold riding than lean, my motor is very healthy so i dont wanna wreck it
