Results 1 to 9 of 9
Thread: 350x running extremly hot help
    goosecreek sc
    22
    three wheeler runs really hot having carb problems anyone think it is related wont run unless choke is on would this cause overheating or is it something else
    Dec 2009
    the ville illinois
    477
    Yes! A lean running eng. will run hot!
    goosecreek sc
    22
    thanks man guess im gettin a new carb
    Apr 2008
    NW, IND.
    842
    Hows the timing? plug gap? could be an intake leak or carb adjustment.Hows the oil pump filter?
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Aug 2004
    Ab Canada
    4,368
    Sounds like a Dirty/gummed up carb, intake leak...Or possibly a plugged up exhaust.
    1985 Tri-Z-
    goosecreek sc
    22
    intake is busted on one side only one screw holding it on is this a major problem
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by ronniecarrigg View Post
    Yea That would most likely be your intake leak problem. Replace it.
    1985 Tri-Z-
    springville, PA
    6,185
    Start up and spray wd-40 around the broken side and see if engine noise changes. My bet is thats where your issue is
    EDIT: Yeah what MTS said
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    goosecreek sc
    22
    thanks for help guys
