Results 1 to 2 of 2
Thread: honda 185s wont go into neutral while engine is running
    Dec 2010
    dunsmuir
    hi guys first post here, I just got an old honda 185s with the auto tranny. and i noticed it wont go into neutral when the engine is running no matter how much i rock the thing back and forth. It goes in neutral just fine as soon as you kill the engine. Other than that it shifts fine all 5 gears, doesnt pop out of gear nothing weird.
    and yes i know neutral is all the way up.
    any idea? thanks guys
    Jul 2003
    Las Vegas, NV
    124
    if the clutch is dragging a little it might make it hard to go into neutral, the clutch adjustment is next to the dipstick. also, you idle could be set too high and the centrifugal clutch could be dragging a little.
    F.U.2 RACING
    Atc90, bandito frame
    Atc185 x2
    82 250 (300 kit)
    83 250R
    200ES Big red
    Atc200X (with lifan motor)
