Results 1 to 7 of 7
Thread: having problems finding a rear sprocket
    4cfed's Avatar
    4cfed is offline Just Too Addicted Arm chair racerJust too addicted
    Oct 2009
    wisconsin
    619
    i need atleast a 38t rear sprocket for a1st gen 200x axle, i can find a 14t for the front for my 86 but i need a 5 bolt 38 or 37 for the rear, everything i find is 40, cant find a smaller one, where should i look?
    86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
    Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
    'let those who slide decide'
    6,798
    http://www.sprocketspecialists.com/ProductSearch2.aspx
    Quote Originally Posted by 4cfed View Post
    4cfed's Avatar
    Oct 2009
    wisconsin
    619
    unnless im blind i only see 40t for the 83-85 200x ..... im running a 1st gen 200x rear axle so i have the 5 bolt sproket hub
    OK
    5,450
    In the link shortline10 provided you can get the aluminum rear sprocket in 28-74 teeth
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Feb 2009
    michigan
    2,387
    here is info on the 1st gen 200x Catalog Search Results Model Years Rear Alum. Part Number Rear Alum. Teeth Range Rear Alum. Std Size Rear Steel Part Number Rear Steel Teeth Range Front Steel Part Number Front Steel Range (C/S) Front Steel Std Teeth Chain Size Std Stock Chain
    599 04
    919 02-04 823 37-72 43 823S 43/44 583 13-17 16 530 530-108
    ATC 200 X (LL 32-50) 86-87 438 34-74 38 534 11-16 13 520 520-86
    ATC 250 R (LL 33-50) 86 437 36-74 39 437S 36-39/41 534 11-16 13 520 520-96
    ATC 350 X (LL AVAIL 32-50) 85 436 34-74 40 436S 40 534 11-16 13 520 520-96
    ATC 350 X (LL AVAIL 32-50) 86 440 34-74 40 440S 40 534 11-16 13 520 520-88
    ATC-110 78-83 199 42-70 199S 49/52 428 428-86
    ATC-110 84-85 431 32-70 431S 49 428 428-92
    ATC-125 M 84-85 431 32-70 431S 49 428 428-92
    ATC-125 M 86-87 431 32-70 750 431S 49 611 12 428 428-92
    ATC-185 80 415 38-71 47 415S 47 5299 10-14 11 520 520-90
    ATC-185 S 81-82 418 28-71 41 418S 41/42 5299 10-14 11 520 520-82
    ATC-185 S 83 417 28-74 41 417S 41/42/44 5299 10-14 11 520 520-82
    ATC-200 80-82 415 38-71 47 415S 47 5299 10-14 10 520 520-90
    ATC-200 83 430 34-74 47 430S 47 5299 10-14 11 520 520-90
    ATC-200 E BIG RED 82 415 38-71 47 415S 47 520 520-90
    ATC-200 E BIG RED 83 430 34-74 47 430S 47 520 520-90
    ATC-200 M 84-85 430 34-74 47 430S 47 5299 10-14 11 520 520-92
    ATC-200 S 84-86 417 28-74 43 417S 41/42/44 5299 10-14 11 520 520-84
    ATC-200 X 83-85 429 28-74 40 429S 40 540 11-14 12 520 520-88
    ATC-250 R 81-82 417 28-74 44 417S 41/42/44 534 11-16 13 520 520-84
    ATC-250 R 85 433
    1985 ATC 250R
    . Team Red Trike
    6,798
    I might have one in stock if you want ?
    4cfed's Avatar
    Oct 2009
    wisconsin
    619
    hahaha.. crap i guess i completely missed that,
    i called my local parts supply whom iv had good luck with parts for older machines, his catalog listed a 35t rear, but when he called to order it its discontinued, so i have a 14t front coming from him,
