When your engine Bogs...
And you've changed the plug 3 times, each time it looks fine, and it still bogs...and your scratching your head thinking to yourself WTF is wrong with this thing...Open up your airbox and check it. I discovered today that after riding in mud and water half the weekend that when the air filter is half way submerged and the water is 2 inches deep in the airbox that the engine doesn't tend to breath that well. Twin Air airfilter should be here Monday or tuesday :-P
good tip there,,,, should check the airbox drain with regular maintenence,,,,
Should clean the air filter after every outing. I guess a bunch of water in the airbox might be noticeable!
I had just cleaned it Thursday, and half a day on friday and 3/4 of a day on Saturday. I think I will check that airbox drain a little more frquently from now on heh.
//ArrowChat Integreation Code
