Thread: How much can a 110 be bored
    Michigan UP
    1,005
    I am looking at getting a piston kit for my 82 110 honda motor that I have in my atc 70. It says that it is a 56 mm piston and the stock is 52 mm, can that cylinder be bored out 4 mm. Also will a stock head gasket work for this big of a piston.
    6,819
    56mm is the max bore and yes you can use a stock head gasket with that kit .
    Quote Originally Posted by briano View Post
    1,736
    I second that if your looking for another person to answer. I did it myself. Im guessing you are looking at the same piston I bought from ebay.
    Michigan UP
    1,005
    Thanks. I want to get this piston, it's 10.5 : 1, I also plan on a cam and pipe and I think I have a carb for it too. The carb will be the last thing as I had to do a bit of finessing to the back of the tank and intake to get the stock carb on it. I can't believe how addicting these things are, I have this 70 with the 110 engine in it and also a stock 70, with another on on the way around Christmas. The next one will have a Lifan or something like it going in it.
    swifty's Avatar
    swifty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    sabula iowa
    381
    i have 2 of those kits in my atc 110's also they charged me double to bore the cylinders that much due to the amout of boring they have to do. i aslo used stock gaskets
    ACT NOW THINK LATER!
    current trikes owned
    minty 86 250sx my rider
    pauter flat track framed 110-123cc with custom goodies
    pauter mx framed 110-123cc with aftermarket goodies
    joker framed 90-108cc with front suspension
    2007 artic cat DVX 400
    dickson sprint framed 73 green us90 with 110 engine
