I am going to look at a 1986 200x tonight. What problems should I look for?
Rusted out tank. Lower corners are most prone to rot out!
Ride: 1986 Honda ATC 200x
Following Mods Done:
-Anodized blue block-off plate
-Factory head light and master cylinder guard
-ITP mudlite SP rear tire/Chengshin turf tamer front
-DG reverse megaphone exhaust
-UNI airfilter
-Moose bars/Protaper Grips/MotionPRO twist Throttle
-CEET classic ATC blue seat cover (should of sent it to mosh :-(...)
-Tuned Carb with a 125 main jet
-COMPLETELY restored gas tank
-RED/WHITE PowerMadd Handguards
-1/4" thick aluminum swing arm skid plate!
Check axle bearings front and rear . Pull the dipstick and check the oil level , give it a sniff to see if the motor smells burnt LOL . If its a runner listen to the top end for noises , knocking , ticking exc .
X2^. Also make sure it is infact an 86-7. They have a square tube frame, very easy to distinguish. If I had a peso for every mis-listed ATC I have seen.......... well....... I would have about 25 bucks. If this is for a full resto, keep in mind 90% of your money will be spent on the sweet white plastic. Good luck!!
Joker 90
1981 Yamaha YT125
1986 Yamaha Big Wheel 80
1986 Kawasaki Tecate KXT500
1987 Kawasaki KXT250B2
2005 Yamaha YFZ450
