My plunger was stuck on mine but I was able to get it out with a pair of pliers and clean it up, now it works fine. I also had a problem with mine idling too high, especially in neutral. When changing gears it would jerk really bad, especially from neutral to first. The front would lift a little bit, but not enough to call it a wheelie. It turned out that one of the bolts that holds the boot from the carb onto the head was striped and it was sucking air through there. After fixing the bolt hole with some helicoil it fixed my problem.
1986 ATC 200s
1985 ATC 250sx
1984 ATC 200x
1984 ATC 200s - Dads [Purchased New]
