Results 1 to 10 of 10
Thread: YT175 clutch
    Wichita, Kansas
    1,359
    YT175 clutch
    Long story short:
    My trike caught fire, replaced all burnt parts required to make it run, ported hell out of cylinder.
    Problem: When ever i shift into gear, my bike dies instantly unless i have the RPMs up a little. Before the fire, everything was perfectly fine, no shifting issues or anything.
    Also, what would it take to make my 1983 clutch into a manual? Which bottom end would i need to rob parts from? To much power for the auto set up.
    Everytime I start getting into my powerband, my wheel starts coming off the ground... porting rocks .. still on stock pipe :-p
    Nov 2006
    Huffman TX
    891
    May I ask how it caught fire? and yes porting is awesome
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    Wichita, Kansas
    1,359
    Floats got stuck or something - larger carb(maybe fuel pump caused needle to not seat?) then something shorted out, as i passed my buddy in a quick run, he said sparks where all over my bike then it caught fire. Headlight didn't light up, tail light worked - thought it was burned out >.<
    this happened right after i put the bigger carb+ throttle cable on.
    Southern MN
    1,875
    The most common clutch mod is from a late 70's DT 175, or MX 175. Im not sure, but only certain years will work, not all of them. You have use the mainshaft from the YT, the shaft the sprocket runs on. The mainshafts on the dirtbike DT and MX is shorter, and the chain will not line up from the rear sprocket to the front. I have been wanting to do this, but havnt been able to pick up a cheap DT, or MX motor or bike for cheap. I think it would be best to but a whole motor, or at least a bottom end, and go from there, then start transfering parts. Vealmonkey knows all the details to this swap. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Wichita, Kansas
    1,359
    Thanks for the tip, but bottom ends with good cranks not cheap - bottom ends with bad cranks are
    By anychance, you think the fuel pump would cause the carb to overflow? The carb i got came off a gravity fed polaris, no pump.
    Feb 2003
    Australia
    927
    Are you sure its got a fuel pump? The tank is above the carb so no need for a pump. Tri-Z's had a pump as the tank was under the seat.
    Its more than likely an oil pump for the 2 stroke oil to mix with the tank fuel.
    Baltimore, MD
    6,088
    The trimoto 175s have a fuel pump. It's very close to the tri z fuel pump. The only big difference is one fuel outlet is straight and one fuel outlet has a 90 degree angle. The fuel pump is mounted under the tank on the left side of the frame and it gets vacuum off the rubber carb inlet on the 82 and off the left side of the cylinder on the 83. The oil pump is on the right side of the engine in front of the clutch assembly.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Nov 2009
    1,147
    When the fuel pump went out on my YT175 it drained all the gas into the engine. It happened over night, so it was cold and wasn't running but when it failed all the gas went into the engine. They are a Mikuni DF44 fuel pump. Incredibly common on snowmobiles.
    sanchez's Avatar
    sanchez is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    where ever i may roam
    228
    is it cheating if you go to a blaster motor for a yt frame
    Wichita, Kansas
    1,359
    I woundered that my self, Not quite a drop in, but extremely close. - tested with a spare bottom end brother had laying around.
