Results 1 to 8 of 8
Thread: Clutch
    Dec 2010
    Texas
    57
    Clutch
    I can't turn the adjusting screw for the clutch on a 1985 250es. Any ideas on how to loosen it. I tried WD-40 already.
    Oct 2007
    Minneapolis mn
    4,067
    loosen the lock nut first....
    Dec 2010
    Texas
    57
    i already loosen the lock nut but the screw is still tight
    Nov 2009
    1,147
    You are supposed to turn it counterclockwise.
    Dec 2010
    Texas
    57
    i managed to loosen it with a vise. just wondering does the trike have a clutch cable or do i apply the brakes when shifting from neutral
    Nov 2009
    1,147
    Once you broke it free did is spin freely? And it felt like it was adjusted properly? Oddly enough I went to adjust the clutch on the 250ES I just got and it is the same way. There is no need to apply the brakes when you shift, just let off the throttle some and shift. When downshifting I will use the rear brake just so the engine and tranny don't do all the work slowing it down.
    Dec 2010
    Texas
    57
    I followed the steps in the manual. I turned it counter clockwise until resistance was felt and then turned it clockwise 1/4 of a turn. Thanks for the help.
    Nov 2009
    1,147
    I mean once you broke the screw loose with the vise it turned smoothly?
