Thread: Im new need help honda atc 110 wont start
    Dec 2010
    nj
    5
    pull start suks was running around begining of september wont start any more even when i pop start it want to ride in the snow this week wht can i do to start it an keep it running
    Nov 2010
    30
    is there spark? is the carb gunked up? is there compression?
    glendive, montana
    1,822
    what does the inside of the tank look like is there alot of rust, and does the fuel flow through the lines, how old is the fuel
    Dec 2010
    nj
    5
    there is a spark and compression the carb might be the problem when i put fuel in the tank gas came out of a hose conected to the carb. the hose looks like it should be longer think it might have rotted off the fuel is newer tank maybe a little rusty but it ran off of a few good tanks of gas when dug put of the grave yard
    Nov 2009
    1,147
    If it hasn't started since Sept. I would put some fresh gas and a new spark plug in it. Make sure fuel is getting where it should. There is also a drain on the carb to drain the float bowl.
    Dec 2010
    nj
    5
    thanks ill try new gas and a new spark plug but if there is gas comeing out of that tube what does that mean?
    pa
    137
    the carb is getting gas but sounds like the carb is gummed up inside. open the carb and clean it real good and i would put an inline fuel filter to catch any debris from your tank.
