Results 1 to 12 of 12
Thread: 400ex rear hubs on a 250r ? ?
    Toledo_Tommy's Avatar
    Toledo_Tommy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Toledo
    279
    I just ordered these hubs off ebay . I guess my question is : are stock 400ex rear hubs wider than stock 84r hubs ? I talked to the seller of these hubs and i was told they will make a 400ex or 300ex 3 in half inches wider. See where i'm going with this ? So does that mean it will make my 84r even wider ? Just something that has been bouncing around in my head this afternoon.
    http://cgi.ebay.com/ebaymotors/exten...mZ280607103503
    Thanks
    OH
    87
    i have 400ex hubs on my 81 its definately a little wider i dunno about 3 1/2 inches doesnt seem like it but then again i never measured it
    Lancaster, PA
    1,738
    its around 3 inches wider, nice cheap upgrade
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    pa
    137
    toledo tommy, the hubs you ordered are wider than stock and the stock hubs for an ex are already wider. this will add almost 3 inches to each side. post a pic when you put these on, im curious to see the stance.
    Nov 2010
    Toledo
    279
    What i'm talking about is: These are Extended hubs that make a 400 / 300ex wider. So the question is: Are 400ex stock rear hubs wider than stock 84r rear hubs ? If so these are extended rear hubs , so would it be even wider than the 3andhalf inches. Because stock 400ex hubs are already wider than stock 84r hubs , These are extended rear hubs made by G-force. So would you think these will be even wider on a 84r ?
    1,736
    works on 110s too.
    Attached Thumbnails Attached Thumbnails 164120_187738377903249_100000012659072_707266_1995355_n.jpg   164120_187738374569916_100000012659072_707265_132616_n.jpg
    pa
    137
    if you put stock 400ex hubs on the 250r it will be about 1 1/2 inches wider than the 250r hub on 1 side. when you get your set from ebay it will add almost 3 inces to 1 side.
    Nov 2010
    Toledo
    279
    ok .
    thanks
    2hundredx's Avatar
    2hundredx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Missouri
    392
    are the spline sizes of the 400ex hubs different than an 85 or 86 250r? arent the 85 axle splines where the hub slides on bigger?
    My first 3wheeler- http://i290.photobucket.com/albums/l...ite200x002.jpg
    Current 3wheeler- 1985 250R
    "Your four wheeler must be fast 'cause you were haulin ass when I passed you on three wheels"
    Nov 2010
    Toledo
    279
    All i know is when i asked the seller of these extended hubs from ebay if he was sure they would fit my 84r he said " Yes 83-84 250r only ". Hope that helps you.
    Gold Hill, OR
    1,295
    Quote Originally Posted by 2hundredx View Post
    Yes, they are different. 24 splines for the 250X/300EX/400EX/450R (there are more) and 27 splines I believe for the 85-6 250R and 350X.
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    2hundredx's Avatar
    Feb 2008
    Missouri
    392
    damn, i wish there were some hubs that would extend the r's axle out.
