Results 1 to 15 of 23
Thread: Best way to clean your engine
    Aug 2009
    Newfoundland, Canada
    915
    Question Best way to clean your engine
    Anyone here have any tips on cleaning an oily and dirty engine? I have all my top end leaks fixed now but the stains are still there. Is there a certain product I can buy that helps to clean my cylinder, head and rocker box?
    St. Agatha, ON, Canada
    1,497
    i would be interested in knowing this also to clean the oil and dirt from my cylinder and the air cooling fins once i get the head gasket done.
    1983 Honda ATC 200e: my first true Man Toy!-Sold for $200 on Victoria Day
    Ice & Trikes 4 Life!
    If Nissan Motorsports = Nismo, does Honda Motorsports = Homo ?
    texas
    567
    Brakeleen is good. It evaporates and leaves no residue afterwards. Gasoline may work too
    Nov 2009
    1,147
    I use SimpleGreen, let is soak in and then scrub it with a brush. Its cheaper than brake clean because you can dilute it. And if you have a well I try to limit what goes on the ground. Even dish soap works good. Brake clean is great for inside the engine when rebuilding but outside it gets just as clean with regular cleaners. One time just to see I did a side by side test on an old 4 cylinder street bike and SimpleGreen did better than Pematex foaming aerosol engine cleaner, and Simple Green worked better, and it was diluted 10:1.
    Aug 2010
    Illinois
    550
    Zep foam cleaner
    ktmbk's Avatar
    ktmbk is offline At The Back Of The Pack Arm chair racerFirst time rider
    Long Island
    154
    Simplegreen always works best for me. brake clean is good on metal parts, just try not to get it on rubber and plastic stuff as it can cause damage.
    6,804
    A soft brass brush is the trick and any type of degreaser , even dish detergent .
    leroy, new york
    1,025
    Cleaner called Purple by gunk super strong stuff
    http://www.gunk.com/prod_photo.asp
    Sep 2008
    Northwest Indiana
    550
    I use soft paints brushes of all sorts of sizes and clean it by hand. My trike usually never gets totally filthy, but I use S100 and water!
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    London, Ontario, Canada
    1,059
    Quote Originally Posted by Tecate 50 View Post
    No wonder the front wheel is never on the ground Buuuzzzzzzzsawwww.
    Nov 2010
    Coos Bay, Oregon, United States
    254
    lolz
    mine: 85 Honda 350x
    http://www.Jeep4PlayOffroad.org
    Apr 2008
    NW, IND.
    842
    +1 gunk..........
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Jul 2008
    hickman, ky
    44
    i used to use a steam pressure washer but dont have any more trikes so dont anymore
    currently "trikeless"......taking donations on the i need-a-tri-z foundation
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    Purple Power and WD40 is god for cleaning engines. WD40 gets out that ugly orange color and leaves a coat of protectant.
    Nothing to ride... for now
    Dec 2009
    the ville illinois
    477
    I use purple power and a steam pressure washer then a good wipe down with wd40
