Results 1 to 15 of 23
Thread: mini hill climb atc 75
    osoyoos bc canada
    1,057
    i will be starting this when i find a few more parts im going to use a 76 xr75 motor 84 xr 80 frame and a trimed 86 cr 250 swingarm for the rear end im going to use a solid steel rod and a dirt bike rear hub
    Attached Thumbnails Attached Thumbnails 100_2219.jpg   100_2218.jpg   100_2217.jpg
    osoyoos bc canada
    1,057
    dug parts for the rear end out of my shed the sprocket thats welded to the axel will bolt to a drit bike hub so i can use the drum brake
    osoyoos bc canada
    1,057
    got a 185 tank for it and put the motor in
    Dec 2009
    Nevada,MO
    81
    This is sick man!!
    Are you going to climb with it as a grown man or in some kind of junior class??
    3 Wheelin' and 2 Strokin'
    osoyoos bc canada
    1,057
    theres no racing in my area im bulding so me and my buddys can find a hill and see how far we make it im going to cut up a bed frame and bolt pieces to the tires for traction
    CanadianThomas's Avatar
    CanadianThomas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Okanagan BC Canada
    270
    Hey dude. some of your pics are enlarging and some aren't. Not that I can't just come over and see it myself. lol. but for other members. Looking real cool so far dude.
    85 Honda 200x, rider build almost complete, need aftermarket rear shock.
    85 Honda 250es, with some work to do.
    osoyoos bc canada
    1,057
    fixed the pic now i got to go clean the shop as you can all see its a mess
    Willamstown PA
    5,824
    differently cool
    osoyoos bc canada
    1,057
    got the motor rebuilt and got it rolling if i bottom out the shocks the motor is a inch from the ground i dont plan on jumping it thoue its top speed will be slow but im building it to go up hills and survive the trip down with or with out the rider
    Nov 2006
    Huffman TX
    891
    Nice, cant wait to see it complete!
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    osoyoos bc canada
    1,057
    i whant to finish it this week im going to use my 77 5speed motor instead of the 76 4 speed and im going to make tire chains intead of wreaking my tires ive made chains for my dirt bike that cut a wet log in half like it was dirt
    osoyoos bc canada
    1,057
    osoyoos bc canada
    1,057
    did some more work today try and guess where my exhaust came from
    Baltimore, MD
    6,088
    I don't know how sturdy that rear axle is. You can use a go kart rear axle. You just need to know what thickness for the axle, there are several different thicknesses. You can also get the hubs for the wheels and a disc brake and a sprocket hub as well. You can get the axles in different widths and with locking split collars, you can have an infinitely adjustable rear axle. Just a suggestion. Keep up the good work. I keep checking in on your progress.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    osoyoos bc canada
    1,057
    the rear end is crap but it is solid steel under the tube but i snaped it when it was on my 125 2 stroke go kart so i put a tube over the brake im trying to find a cheap one or get a new bearing and weld the crap out of it there is a rear end im going to look at tomorrow hopefully the spockets in the right spot the muffler is off a 78 sp 370 back presser is not a problem these motors run great on top end with straight pipes im only useing it cause i need a spark arester for the summer if you dont have one in bc forestry has the right to take your bike and you cant get it back my area is bad for forest fires
