Results 1 to 15 of 15
Thread: New 36mm carb for my 84R . . . .
    Toledo_Tommy's Avatar
    Toledo_Tommy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Toledo
    279
    Now this didn't all just fit right together , I ordered a 85 intake boot so the 36mm carb would fit. Wrong with the length and offset of the intake with the spacer it pushed the carb into the exhaust . Looked and looked online and found nothing . So i went to PR racing ( power rider ) and told the guys there of my problem . He said here i got something that might help you out , a intake boot off of i don't have no clue but it was shorter and off set to the Right ! Everything then fit together perfect , almost like it was oem that way. Haven't taken it for a spin yet but she fired right up and sounds great !
    [IMG][/IMG]
    I just wanted to bring this up because as of last night i didn't think i was going to be able to put this carb with the reed spacer on this trike, i'm glad i didnt give up!
    Southern MN
    1,875
    Very nice upgrade for the 84 R. What modifications do you have done to your machine? I think that a 36mm would be a lot of carb for a 250cc bore, even with pipe, and free flowing filter, right? Unless you have a hondaline 300 or something. Is that carb a Keihin PWK airstriker? Let us know how she runs! Thanks for the info!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Nov 2010
    Toledo
    279
    Huh . ? . ? This carb will not work on a stock 84r ? ohhhh noooo ! hehe . . . Mild port n polish , milled , .20 over , and piped . This motor is thirsty , i'll let you know how it runs.
    sbjones73's Avatar
    sbjones73 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    wisconsin
    414
    it's not that it won't work, but that carb is kind of big for what u have. it will still work though.
    lets see some pics of trike
    84 250r gone,
    87 suzuki lt250r trail machine, gone to fund ice racer,
    85 250r ice racing project started !!!!!!
    Sweden
    20
    You got a FL350 intake. And the carb is a quadvent PJ by the looks of it
    Alvarado Texas
    94
    That carb should work nicely if you jet it correctly. I got a 39mm pwk on my 250R and it was one of the best upgrades that I've done to it. Your defenitly gonna notice a difference in power
    Nov 2010
    Toledo
    279
    Yea. When you think about it tho it's really not that big compared to the 85-86 R's running the 34mm . I jumped my Banshee from 26mm up to 34mm with reed spacers and that shee will damn near pull your arms off once it gets traction. I can't wait to take this for a spin but right now it's down due to the previous owner welding the shift lever to the shift shaft and the weld broke. So i should have that all back together today , had to wait on my new shaft and seal to get in. I'll post pictures of it soon , it was a barn find . Found this on the carb . .
    "Keihin PWK 36mm Quad Vent:
    Has the same body and outside openings dimensions as the 38mm, but a smaller bore center. Smaller bores make it easier for engines to pull air through the carb at a faster velocity. This usually translates into borrowing top end performance and giving to improved bottom end. On 250cc engines, 36mm is a great trail and tight MX carb."
    Sweden
    20
    Looks as a PJ, Pwk dont look that way. Check the slide. Pwk has a D-shaped slide
    Dec 2010
    shelbyville mi
    61
    its a airstricker take the filter off and take a pic of were it goes then ill know for sure
    1984 250r
    300 big bore
    bassinni pipe
    boysen reeds
    34mm pj
    k&n pod
    1986 atc200x needs help
    2 banshees 1 for trails 1 for dune/drag racing
    Lauderdale County, Alabama
    2,029
    Julle beat me to it, looks like it's off of an FL350 Pilot.
    OK
    5,450
    Quote Originally Posted by Chazz of Blades View Post
    FL350 was an Odyssey, FL400 was a Pilot :-)
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Sweden
    20
    Sorry to be a pest but that carb body aint a PWK. The Pwk dont have the Keihin logo written verticaly on the slide body, its to thinn there. Airstrykers are only avalible in 35mm and 38mm PWK and both are quadvented! Quadvent is avalible in 36mm. That is a PJ quadvent
    Nov 2010
    Toledo
    279
    You are right . . Airstriker also has the brass idle screw , this does not . I'm 99.9 % sure it's a 36mm quadvent carb , Ill post the part number for it once i get back out to the garage.
    2,029
    Fl250 Oddyssey, Fl350 Oddy, and an Fl400 Pilot.
    Nov 2010
    Toledo
    279
    I measured the carb bore at the middle neck , it measured 35.84MM . It is a PJ Keihin 36mm carb but not an airstriker carb , All i know is it runs great and fires right up with this carb on it.
